M govenor tweaking
bindernut
09-23-2003 22:44:18
Hey gang, how can I tweak the govenor on my M to get more RPMs? Thanks
Binernut
rustyfarmall
09-24-2003 07:40:45
 Re: M govenor tweaking in reply to bindernut, 09-23-2003 22:44:18
Check the archives on the tractor pulling forum, pretty much everything you need to know is there.
One thing I will add, first, make sure your gov. is operating properly, and giving the rated RPMs that are supposed to be there. These things have a lot of hours of use on them, and excessive wear will result in less than desirable performance. If you are handy, you will discover several things you can do that won't cost a cent.
Aces
09-24-2003 07:22:27
Bindernut you don't want much more because the 4 cylinder will not take much to cause viberation.
