super a grill
ovil winburn
09-25-2003 19:18:18
I am trying to restore a 1954 super A, and the grill is in pretty bad shape. does anyone know where i can buy either a used one or as a last resort a new one. thanks ovil winburn ocala, florida.
BIG JOHN
09-26-2003 14:59:44
 Re: super a grill in reply to ovil winburn, 09-25-2003 19:18:18
If you are not a purest about your tractors the grill from an A, B,& C will also fit your Super A.
While the size will be correct the cut of the bottom pan in some cases will not be correct but it will work with some minor modifications on your part.
GOOD LUCK
Hugh MacKay
09-25-2003 19:58:21
Ovil: Now you are getting into the expensive part for a Farmall Super A. Because of design these grills took a beating over the years, thus used ones are in very short supply. There are a number of sources of reproduction sheet metal parts for these and all quite expensive. I have never been in need for these so not right up on all suppliers. Most any of your local tractor salvage yards will know where to look for these.
