Stuck exhaust valves
Out Back Dave
09-25-2003 22:44:03
Hi Folks,
Great reading, as always. I just read Nebraska Cowman's last post. Thanks for the tip about the manafolds and head gasket. What type of "cement" were you thinking about? Copper seal? Silver spray paint? Something in the "Permatex" line? I got # 1 to pop up with a tire spoon. It's now working fine. The #2 however, the one that was stuck fast, is now moving with a hammer and brass drift. It still won't come back up on it's own yet, but the rope trick in the cylender brings it up part way. It looks like I've got another 1/4 inch to go. I just go out every night and work penetrant back and forth for a couple dozen times, and let her set for another day. I discovered I could take the clip off the stem and get more travel down to carry more oil into it. Had to go to a meeting tonight, so I didn't get to play with it. The rust now appears to be breaking down. First time I tried the rope, I heard something snap, and I thought I had broken the valve head off inside. Pulled the rope back out, and fished around the top of the piston for the sickening rattle of a broken valve, and found nothing. Then took a quick peek at the stem, and found it had moved a mere 1/16th inch. What a relief...! It now can be driven back and forth a good 5/8th inch. It has taken all of the combined suggestions offered to get it moving, and now I'm sure I can get it free. But, that first SNAP sure is a scare.
When it returns a little on it's own, I'll go to the reversing drill suggestion and finish it off. Think I'll just leave the rope inside to aid in holding the valve in place to reinstall the spring and retainers. Might even be simpler than shop air preasure.
Right now the opperative word is "patience".
Thanks All!
Dave in WA
Nebraska Cowman
09-26-2003 18:54:22
 Re: Stuck exhaust valves in reply to Out Back Dave, 09-25-2003 22:44:03
Quote "What type of "cement" were you thinking about? Copper seal? Silver spray paint? Something in the "Permatex" line?"
Those all sound good to me. I like the old Indian Head gasket shellac. but it sounds like you are going to get it by paitience and fortitude rather than disasembly.
rustyfarmall
09-26-2003 11:49:22
If anyone ever figures out how to market "patience" they could be rich, I seem to run short of it sometimes.
