oil seal for W400
Eric
09-27-2003 10:45:26
Can any one help with my 400 have got various new backend seals and brake discs from local IH dealer but i still need the oil seal for the main shaft entering gearbox from clutch dealer can't find a part No' for this seal can any one help with the part No' or suggest where to find this seal. tractor is 1946 W400 no TA
thanks in advance Eric..... ...
CNKS
09-27-2003 13:16:25
 Re: oil seal for W400 in reply to Eric, 09-27-2003 10:45:26
The dealer should have this. If you can remove the seal without destroying it, any bearing/seal place can cross reference it or match it with something else. You mean 1956 W400 don't you? I can't believe your dealer doesn't have that. One of the most common leaks on earth.
