HELP!!!!!!!!!!!!!!!!!!!!!!!!
Dave M
09-27-2003 14:08:18
I think i blew the head gasket on the W-9! Got air bubbles coming in the radiator and spewing coolant all over and water in my oil. I need the diagram that shows the order that the head should be torqued in and the head bolt torque. Also where would i find a head gasket for it? Thanks a lot
Dave M
Bill B
09-28-2003 05:41:35
 Re: HELP!!!!!!!!!!!!!!!!!!!!!!!! in reply to Dave M, 09-27-2003 14:08:18
When you take off the head, look carefully at the gasket to try to determine where it failed. If you find a failure area, look at the deck and the head in that area to see if there is a problem. The head may need to be surfaced. If you find no failure in the gasket, there may be a crack causing the leak.
Bill L Md
09-27-2003 16:55:26
Make sure when you get the head off you take it to your local machine shop and get that head magnafluxed,to make sure your head is not craked.
Bill
09-27-2003 14:19:30
This sounds like a mess. Hopefully a head gasket is all it is and not a cracked head. Try Mike at Steel Wheel Ranch for the gasket. His number is 785-548-7437. I don't have the shop manual for the torque values, but Mike should be able to tell you that also.
Dave M
09-28-2003 07:03:57
 Re: Re: HELP!!!!!!!!!!!!!!!!!!!!!!!! in reply to Bill, 09-27-2003 14:19:30
Thanks
