300 block same as H/M?
Rick P
09-28-2003 09:28:35
I have a 300 with a c175 I think. Is there another block that is the same? Thank you in advance. Rick P
Haas
09-28-2003 12:39:01
 Re: 300 block same as H/M? in reply to Rick P, 09-28-2003 09:28:35
According to the parts CD, the Super H and the 300 share the same crankcase (engine block) part number 364265 R1. The H has a different number. The M engine is entirely different and would not fit.
Rick P
09-28-2003 14:26:18
 Re: Re: 300 block same as H/M? in reply to Haas, 09-28-2003 12:39:01
Thank you Haas I'll have to look for one or a 300 block. Thanks again. Rick P
justin
09-28-2003 15:20:30
 Re: Re: Re: 300 block same as H/M? in reply to Rick P, 09-28-2003 14:26:18
make sure the block is a 300 or 350 farmall block, as the utility blocks are different.
sammy the RED
09-28-2003 10:33:51
H is 152 cu. in.
M is 248 cu. in.
Super M is 264 cu. in.
300 is 169 cu.in.
350 is 175 cu. in.
Rick P
09-28-2003 11:02:16
 Re: Re: 300 block same as H/M? in reply to sammy the RED, 09-28-2003 10:33:51
Thanks Sammy do you know if any are interchangable Thanks again. Rick P
jakee
09-28-2003 18:37:44
 Re: Re: Re: 300 block same as H/M? in reply to Rick P, 09-28-2003 11:02:16
300 utility is diffrent ? i just put one in a 39 H.
justin
09-28-2003 20:19:36
 Re: Re: Re: Re: 300 block same as H/M? in reply to jakee, 09-28-2003 18:37:44
I am not sure there are any physical differences, but the part numbers are different
