Got 2 H decals left over? Where to put
Robert in Md.
09-28-2003 12:18:27
Been putting on the decals on my newly painted 1950 H and have two small decals that I don't know where to put. The first one is a small yellow semi-circle with "OPEN" and an arrow to the right. The second one is about 2" X 3" white with "BE CAREFUL" Do not make short turns at high speeds. Always lock brake pedals together for traveling in high gear etc. Can someone please tell me where these decals go so I can be finished with this tractor. Thank you, Robert
Bill B
09-28-2003 12:39:26
 Re: Got 2 H decals left over? Where to put in reply to Robert in Md., 09-28-2003 12:18:27
The small one is for the radiator shutter control. If you have a small crank near the bottom of the steeringpost, or thereabouts, it goes there. If you dont have the crank thing, then your tractor does not have shutters, and you dont need the decal. The brake warning decal goes on the gas tank, centered, and with the bottom edge of the decal 18 and a half inches back from the edge of the hood.
Tractor Dan
09-28-2003 12:36:13
the open one is for radiator shutters, on my h its right next to the kill switch not sure were the other gos
Robert in Md.
09-28-2003 12:57:26
 Re: Re: Got 2 H decals left over? Where to put in reply to Tractor Dan, 09-28-2003 12:36:13
Thanks Bill and Dan, I'll through the OPEN decal away and I have already put the brake warning decal on . Finally finished except for one item. I have the light mounted toolbox on this tractor and the toolbox lid vibrates and makes alot of noise at any speed above idle. I have tryed little rubber dots with the glue on the back , its no better. Next I'm going to split some small rubber tubing and slip it over the top edge of the box so the lid will sit on it. Maybe this will help. Thanks guys.
