Farmall Steel wheels??????
Matt
09-29-2003 04:32:49
Hi, I know that Farmall H rear steel wheels are 51" diameter(minus the lugs). Does anyone know what the diameter is for the M and the F12/14s and also the axle sizes?
Thanks.
Matt -THANK YOU
09-30-2003 03:45:29
 Re: Farmall Steel wheels?????? in reply to Matt, 09-29-2003 04:32:49
x
Harold H
09-29-2003 18:57:35
Many different size and type steel wheels were available, especially for the earlier F series tractors. For example, at least eleven different steel rear wheels size/types were available for the F-20. Standard steel on F-12 and F-14; 22 3/8" x 4" front, 54" x 6" rear. Standard steel on the F-20; 25" x 4" front, 40" x 6" rear. Standard steel wheels on F-30; 25" x 4" front, 42" x 12" rear. Standard steel on H; 22 1/2" x 3 1/2" front, 51" x 6" rear. Standard steel on M; 22 1/2" x 4" front, 51" x 8" rear. Standard steel on W-4; 22 1/2" x 3 1/2" front, 40" x 8" rear. Standard steel on W-6; 22 1/2" x 4" front, 42" x 10"rear. Standard steel on W-9; 30" x 6" front 48" x 12" rear. Standard steel on WR-9; 34" x 6" front, 54" x 12" rear.
Harold H
CNKS
09-29-2003 18:34:34
M was 51 inches also. I can't help you with the axle sizes, except the M axle had a larger diameter than an H. The rear wheels won't interchange.
Wayne
09-29-2003 19:39:11
 Re: Re: Farmall Steel wheels?????? in reply to CNKS, 09-29-2003 18:34:34
I am assuming you are mostly concerned with the back wheels. We have almost always left the front on rubber on to eliminate jarring the radiators all to pieces. I have an H and my dad has several Farmall F-12's. I haven't actually put the F-12 steel wheels on the H but they measure the same axle diameter. I know an M has a larger diameter axle. To me the F-12 wheels seem quite narrow for the H. We have thought about using one complete F-12 steel wheel and an outer wheel (no center or spokes) and lugs bolted together to make it wide enough. Last time I checked F-12 steel rears were running about $150 per set and I seen a rear set for the H for $300. Should have got them... That's here in KY.
Harold H
09-30-2003 04:52:31
 Re: Re: Re: Farmall Steel wheels?????? in reply to Wayne, 09-29-2003 19:39:11
Although rear wheels from a F-12 or F-14 will go on a H, They are not an exact fit. The F-12/14 rear axle is 1/8" bigger diameter than the H rear axle which under heavy conditions might allow the wheel to move as it does not exactly fit the axle.
Harold H
Wayne
09-30-2003 17:31:46
 Re: Re: Re: Re: Farmall Steel wheels?????? in reply to Harold H, 09-30-2003 04:52:31
You'r right! I knew there was something I forgot since it has been a while. I do remember some of the Amish had the F12 rears on an H, but they mostly used it as a power unit.
