winterizing
tractorhead
09-29-2003 05:43:28
Im new at tractor collecting, I aquired 3 farmalls this summer. What do I do about winter, which can be sever here in north west IN. do I drain all gasoline, use stable, or just try to start them ever so often,thanks guys for the help.
tractorhead
09-30-2003 11:32:31
 Re: winterizing in reply to tractorhead , 09-29-2003 05:43:28
HEY CHRIS IF I WENT OUTSIDE AND HOLLERED YOUR NAME YOU WILL PROBABLY HEAR ME, I LIVE WEST OF 41 AND 2 MILES NORTH OF 2.
Nebraska Cowman
09-29-2003 19:29:39
it is my opinion that the battery should be stored where it won't freeze. But if you put the charger on it once and a while that would be ok too. kepping the gas tank full might be a good idea but i don't and never have trouble. Make sure they have antifreeze or drain then but i assume you knew that.
Chris B.
09-29-2003 19:14:37
Where at in NW Indiana? I'm here in Lowell.
I don't do much for winterizing since I use her for snowplowing. (Not too much of that last year.) Just make sure that there's no water in radiator, battery is charged, and the oil is a good viscosity--15W-40 Delvac is the ticket for me. If you let her warm up for a few minutes, your tractor will think it's summertime.
Chris B.
tractorhead
09-30-2003 05:29:40
 Re: Re: winterizing in reply to Chris B., 09-29-2003 19:14:37
for chris B. I also live in Lowell,we might be neighbors.
Chris B.
09-30-2003 07:21:15
 Re: Re: Re: winterizing in reply to tractorhead, 09-30-2003 05:29:40
Where at in Lowell? I'm a couple miles west of 41 and a bit north of 2. Send an e-mail if you like.
Chris B.
Roger
09-29-2003 19:09:33
I live in Western Wisconsin were it gets cold in the winter. I now am up to 7 Farmalls so winter is a concern. With the tractors that I am not going to run all winter I add stabilizer, fill the tank with gas, add a can of Heet (helps to keep the rust from forming in the tank), and squirt oil in each cylinder. Then I put the battery charger on the batteries every couple months. In the spring they start like I just shut them off. Roger
Jcnc
09-29-2003 14:42:24
I also start the "H" every couple of weeks and run it awhile to keep the battery charged.....
Walt
09-30-2003 06:35:37
 Re: Re: winterizing in reply to Jcnc, 09-29-2003 14:42:24
Stay away from the regular Heet. It has methanol in it and is corrosive. Use Iso-heet, it has isoprople alchol in it and is 100 times better.
Take 2 small bottles and mix a small amount of gas, Heet and water in one, and Iso heet in the other one. Shake them up and see the difference.
Kevin In Michigan
09-29-2003 06:35:46
For me I fill the tank (ok I leave about a inch) and Stable and check the coolant making sure I am safe to about -40°F. I come back in the spring and she runs like a champ.
