Super H Head and Block Numbers
Jeff
09-29-2003 07:50:05
I recently looked at a very nice Super H. Before I buy it, I want to make sure it has the correct block and head in it. How can I tell the difference between an H, super H, 300, and 350?
Thank You for your assistance.
rustyfarmall
09-29-2003 16:34:50
 Re: Super H Head and Block Numbers in reply to Jeff, 09-29-2003 07:50:05
Take a look at the engine block somewhere behind the oil filter, if it is a super H, the number you see will be c-164.
Pat H
09-29-2003 13:46:23
a Super H will have a C-164 block an H will have a C-152 block I believe a 300 will have a C-169 block and a 350 will have a C-175 block. If you e-mail or post the serial number of the tractor you're looking at I can tell you within a couple hundred numbers what your block serial number should be. I also have a list of super H's started in case you're looking for a specific serial number. Hope this helps. Pat in Wisc.
