Behlan power steering unit on Super A
Red 4 ever
09-29-2003 11:33:05
I have a Super A that I mow a lot of yard with I am getting older and arms are getting tired can a Behlan unit be mounted on a Super A using the hydraulics that are already on the tractor?
Gary-Miss
09-29-2003 18:54:17
 Re: Behlan power steering unit on Super A in reply to Red 4 ever, 09-29-2003 11:33:05
Yes, it can. Cut the small line (pressure line) and run the pump side to the inlet and connect the outlet side to the other piece of pip. The hydraulic pressure will flow through it. The only time your hydraulics won't work is if you hold the steering in a limit and make the relief valve work in the pump. I rigged one up on a Massey Harris 44 several years ago.
