need your help
old fashioned f
09-29-2003 20:14:51
Good day gentlemen,
Well, I've exhausted all my conventional sources and so I come to y'all for a little help. I appreciate any you can offer. Here's my situation. I have an international hydraulic plow (not sure of the model). It is a four bottom but can be converted to a five bottom if desired. My trailing wheel is shot. The hole in the wheel for the valve stem is all rusted up and full of points that have punctured my tube. I have a good many acres to plow and only a two bottom j.d. trip plow to use behind my R. I could really use that four bottom. I've tried all my sources but cannot find a replacement wheel for it. Do any of you all know where I might find one or perhaps have one that you'd sell. I appreciate the help. God bless.
--old fashioned farmer
hal
09-30-2003 04:56:53
 Re: need your help in reply to old fashioned farmer, 09-29-2003 20:14:51
you can take an old tube and cut it to make a boot like they used on the old tube type tires on automobiles. it will help to protect the new tube. if you have a problem area, you can put a patch in that area and it will give you even more protection from punchering your new tube. clean up the rim with a wire brush on a grinder or file and weld it up as everyone else has suggested and put it back together. it should get you by. then you can keep looking for one at a farm sale.
Bob, Nor. Mn
09-29-2003 21:14:13
Good fix for any rim is to braze in a heavey washer the hole being the size of the tube stem on the inside of rim, smooth down any rough spots with a sander.Will last longer than most of us.
Farmall Nut
09-29-2003 21:00:43
Remove the tire and clean up the rim in the valve stem area. Take a square peice of scrap tube and glue it over the old valve stem hole from the inside. Drill a new valve stem hole and you are fixed up. This will provide you with a useable quick fix that has worked well for me.
Farmall_Nut
09-29-2003 21:10:18
 Re: Re: need your help in reply to Farmall Nut, 09-29-2003 21:00:43
I want to clarify that you will need to drill the new hole at a different location on the rim.
