Super H carb problems
Hoppy
09-30-2003 05:59:40
I'm still having problems with this carb(361525R92). When I adjust the load jet 4-5 turns out it runs good but smokes black, when I turn it in to about 2 turns in I get rid of the smoke but it falters as soon as I open up the throttle. Adjusting the idle jet changes the running but don't get rid of the black smoke. I have lowered the float some already. Any Ideas? Thank You
the tractor vet
09-30-2003 07:46:41
 Re: Super H carb problems in reply to Hoppy, 09-30-2003 05:59:40
Buy chance the main jet did not fall out of the carb did it and when ya had it apart ya did not end up with any extra parts. If ya drop the float level it will run lean when it needs gas so i never drop the float level . Do you have a restrishion in the air filter . It is had to see what it is doing over the magic box , Is the timing set correctly and is the valves set there are a hundred things that come into play . If the idel bleed screw is out of wack then it will smoke if there is and internal crack in the carb it will smoke . Let me know what is up with it.
Jim
09-30-2003 14:34:10
 Re: Re: Super H carb problems in reply to the tractor vet, 09-30-2003 07:46:41
aThe super H carb is different than the H and the M the Mian jet is a fixed jet and 5 turns out on the main jet is for max power thats why the smoke turn in for less power. After this is done let tractor come to running temp then set your idle jet. I had the same problem when rebuilt mine had to get a book on the thing.
