Anbody every mounted a different engine in a 340D?
Farmer Bob
09-30-2003 18:03:17
Farmall 340D (Row crop)engine (D166)is toast. It appears from factory that the block was bored at an angle instead of straight in. 3 of four sleeves are cracked, block has 4 cracks, crank journals are egg shaped and the list goes on. Wondering what other engines would bolt up with minimal fuss and machining work. Parts for these somewhat rare buggers are getting hard to find.
big fred
10-01-2003 10:31:27
 Re: Anbody every mounted a different engine in a 3 in reply to Farmer Bob, 09-30-2003 18:03:17
Bob, it was probably drivin' in Chuck's driveway that cracked that block... ;o)
IH made a TD-340 crawler, suppose they have the same engine? Might be a little more common. You might have some luck with a couple of the salvage yards down in California. Seems I recall a couple crawler salvage places between Bakersfield and Fresno along Hiway 99, but I sure don't recall the names of the places. Not much help, am I.
Farmer Bob
10-01-2003 21:08:01
 Re: Re: Anbody every mounted a different engine in in reply to big fred, 10-01-2003 10:31:27
You may have a point there BF! I talked to Chuck last night in fact. Appreciate the thought on the salvage yards, but like you said, without names or numbers, I'm still at a loss.
Try these
10-03-2003 00:44:52
 Re: Re: Re: Anbody every mounted a different engin in reply to Farmer Bob, 10-01-2003 21:08:01
Florin Tractor Parts
8345 Florin Rd.
Sacramento, Ca 95828
800-223-9916
Myers Tractor Parts
131 W. Riverdale Ave.
Riverdale, Ca 93656 (Southwest of Fresno)
800-344-9494
F.P. Smith Equip.
3190 Ramsey Rd.
Suisun, Ca. 94585 (North of San Francisco)
800-55-TRACTOR
Nyssa Tractor Salvage
Nyssa, Ore.97913
541-372-4020
Draper Tractor Parts
1951 Draper-Brown Rd
Gasrfield, Wa. 99130
800-967-8185
If you have it, look in the back of Farm Show magazine "25 Years of Great Shop Ideas".
Slowpoke
tom
09-30-2003 18:12:55
where are you located? I have a complete D166 engine
Farmer Bob
09-30-2003 20:22:16
 Re: Re: Anbody every mounted a different engine in in reply to tom, 09-30-2003 18:12:55
I'm in Washington State. Where are you?
