farmall m stops pulling
Papa H
09-30-2003 18:39:10
I have a m and almost out of the blue it stopped pulling my disc.If I change the angle it will pull.The engine speed stays put and it basicly justs stops pulling.need some help. I just installed new clutch a few weeks ago and it was doing great.
Randy in NE
10-01-2003 04:30:55
 Re: farmall m stops pulling in reply to Papa H, 09-30-2003 18:39:10
If the engine speed stays up and your ground speed slows down then you are slipping the clutch. Check to see how much free play you have in the clutch pedal? Is it adjusted to specs? If you just replaced the clutch and this is the first that you have worked it then it is possible that when you originally adjusted the clutch the clutch pack or pressure plate may not have been seated properly and now it has worked itself into proper alignment. Oil on the clutch/pressure plate could also cause it to slip.
Farmall-Nut
09-30-2003 20:49:49
It doesn't have the M&W hand clutch, does it? Other than that It's beyond me.
Papa H
10-03-2003 03:35:38
 Re: Re: farmall m stops pulling in reply to Farmall-Nut, 09-30-2003 20:49:49
As in reply to Farmall Nut. Yes this one has a M W clutch and no I am not to smart on it. But i do notice a noise in around the middle of tractor when it stops pulling. Help
