Super M Thermostat - 195 degree?
bbauman
10-01-2003 07:08:06
Had the local mechanic order a thermostat for my Super M. What he gave me is a 195 degree one, is that right?
Installed it and the tractor promptly boiled over within 10 minutes. It has since been removed.
Haas
10-01-2003 18:33:27
 Re: Super M Thermostat - 195 degree? in reply to bbauman, 10-01-2003 07:08:06
The parts CD calls for the thermostat to be 165-190 degrees. I assume that means it starts to open at 165 and is fully open at 190. I think thermostats are usually called by the temp they start to open. Thus a 195 degree stat is too much for the Super M. IH part number is 33814 DB
Bob M
10-01-2003 18:30:13
I've run a 180 deg t'stat in my Super M for several years - it works fine. I find it runs better with a 180 t'stat than with it does with a 160 - especially under light load in cool, damp weather.
RickB.
10-01-2003 08:36:36
Probably got you one for a kerosese M. They will run 10-20 deg hotter than a gas T'stat. i'd be looking for one around 180.
the tractor vet
10-01-2003 07:12:02
Ya didn't put it in backwards did ya ???? i screwed up once like that they don't go in the way ya think they should.
bbauman
10-01-2003 08:15:34
 Re: Re: Super M Thermostat - 195 degree? in reply to the tractor vet, 10-01-2003 07:12:02
Put it with the bronze button thing down (towards the motor). After removing I tested it and it did open at 195. Just thought that was a bit high for a tractor.
the tractor vet
10-01-2003 08:24:12
 Re: Re: Re: Super M Thermostat - 195 degree? in reply to bbauman, 10-01-2003 08:15:34
Just setting here tyren to think what goes up and what goes down today i am brain dead and it has been a couple years since i put one in but the first one i did put in backwards and felt like a idiot. I can't remember just what the correct temp should be but i am thinking either 160 or 180.
Dr.EVIL
10-01-2003 10:37:09
 Re: Re: Re: Re: Super M Thermostat - 195 degree? in reply to the tractor vet, 10-01-2003 08:24:12
I think either 160 or 165 was the OEM rating. They ran those gas Farmalls pretty cool.
Dave 2N
10-01-2003 18:20:28
 Re: Re: Re: Re: Re: Super M Thermostat - 195 degre in reply to Dr.EVIL, 10-01-2003 10:37:09
I think you are right; it takes a lot to get those older Farmalls even a little bit warm.
