Order Farmall Cub Parts Online
Farmall Cub Serial# location Help...
Tyler
10-01-2003 10:39:14
Hello guys, Just bought a Cub and i cant find the serial number, One book I have says it is on the right hand side of the steering hsg, the other book says on the left side of clutch hsg. Is it lightly stamped where it is hard to see anyway ?? Any advice appreciated.
Thanks, Tyler
Bigdog
10-01-2003 12:27:33
 Re: Farmall Cub Serial# location Help... in reply to Tyler, 10-01-2003 10:39:14
Cub serial number is located on an aluminum plate riveted to the lower radiator casting. It is on the right as viewed from the operator platform. You will find it on the side of the casting just below where the steering shaft enters the housing. The number you found on the left side is the engine serial number.
Tyler
10-01-2003 11:08:27
I found a number stamped on the left side of the engine block just below the side cover. it is 53369.
