Sickle mowers???
Gary_N_WV
10-02-2003 07:47:26
I've searched through the archives but not having much luck.
Can someone tell me some model numbers of mowers that fit a Farmall C ? Side mowers? Rear mowers?
I live in an area that is "ford" country so it's not easy for me to look to see what others have.
Maybe you can suggest a book on implements that I could get to learn from.
Any help is appreciated !
Thanks !
Gary
Sid
10-03-2003 03:36:12
 Re: Sickle mowers??? in reply to Gary_N_WV, 10-02-2003 07:47:26
The original mower for the C was the C-21. This was followed by the C-21-M for the Super C. The main difference between the two mowers was the method of attaching the drawbar to the axle housings. I don't know whether a mid-mounted mower was available for the C. Hope this helps. Sid.
gblack
10-02-2003 22:32:01
I have SC all 2 with 2 point hitch that are converted to a 3 point hitch. One tractor has had a NH 451 9 foot sickle mower attached to it for 22 years. Works great. the original Ih mowers that are for a C are scarce as hens teeth, and the NH 451 works well. I cut 5.5 acres per hour with it.
Jim in michigan
10-02-2003 14:02:39
I have 2 mowers that will fit the Super C,,, one is a Model 25 tractor mower, it is made by IH and has a single rear tire,,it mounts on the drawbar and is lifted by a cable running to the touch control,,,I also have a older style that hangs on the rear of the tractor, both of these were bought new with Super C tractors,.,I have these 2 mowers up for sale,,,Jim
