Adding remotes to C/IH485-380B
Mac
10-02-2003 08:35:25
Is it possible to tap into any hyd lines with 3 way ball valve and return to case on this tractor?
Which line is best for loader and 3pt hoe? I don't want to starve transmission and ruin it. I have tubing diagram, but no flow diagram.
Thanks,
Mac
Diesel Don
10-03-2003 07:24:34
 Re: Adding remotes to C/IH485-380B in reply to Mac, 10-02-2003 08:35:25
I don't know the particulars about that tractor, but if it is similar to other newer IH tractors, the return has to be routed back to the transmission or you will have problems. Without any more details on that tractor's hydraulic system, I can't help you much more.
Mac
10-03-2003 12:29:19
 Re: Re: Adding remotes to C/IH485-380B in reply to Diesel Don, 10-03-2003 07:24:34
it's basically an IH485 in industrial skip loader disguise, but this one has been robbed of remote valves and power beyond manifold. I will e-mail a scan of tubing schematic.
