FOR THE RED MAN ,IH 460 U HYDRUALICS PROMBLEM??
CHRIS
10-02-2003 17:01:30
IM BUYING A IH 460 UTLITY DOES THE PTO RUN BY HYDRULIC PRESSURE OR CLUTCH PLATES? THE PTO IS SLUGHISH AT LOW ENGINE RPM. THE P/W STERRING DOES NOT WORK AT LOW RPM IF HIGH,THE PUMP IS WHINNING AND STERRING IMPROVES.IS SOMETHING WRONG WITH THE PUMP? THANKS CHRIS
Jimmy King
10-03-2003 04:55:14
 Re: FOR THE RED MAN ,IH 460 U HYDRUALICS PROMBLE in reply to CHRIS, 10-02-2003 17:01:30
The P T O has an over center set up with clutches. The power steering has it own pump bolted to the hyd. pump sounds like the power steering pump is wore out.
Aces
10-02-2003 20:08:56
The PTO has it"s own clutchs in the housing at back of tractor. Never had much to do with power steering on the 460 U.
