engine part number
HEF
10-02-2003 18:54:26
making room for my new to me 1947 H. need to try to find out what this new short block part number?
372544 R 4 might fit.got block in the 70's from a old international dealership building we bought.new cam,pistons c/s rods timming gears.thanks for any help.
HEF
10-03-2003 19:14:50
 Re: engine part number in reply to HEF, 10-02-2003 18:54:26
more info on engine 3.5 bore--3.45+- stroke,does not look like sleeved block,stamped left very back u84,stamped under dist mount33323 3,crank at rear 10 67 cast, h stamped mba cast, main cap #367518r2.some one said some thing about a 504,im looking in to that eng .thanks still would like more help.6cyl eng
Stan(VA).
10-03-2003 20:28:38
 Re: Re: engine part number in reply to HEF, 10-03-2003 19:14:50
The 504 gas is a C153 4 cyl, 3 3/8" bore x 4 1/4" stroke. I'm not that familiar with the 6 cyl's, but the closest I've found so far is the 460, which has a C221 6 cyl, 3 9/16" bore, 3 11/16" stroke. If you have access to later vehicles check combines, swathers, forklifts, maybe even trucks from mid to late 60's and early 70's.
Stan(VA).
HEF
10-03-2003 19:13:40
Stan(VA).
10-03-2003 07:41:37
It might not be a tractor block. Poss a power unit for a combine, forklift, etc. It might help to post the letter from a date casting code, and how many cylinders, then bore and stroke measurements.
Stan(VA).
Gary_N_WV
10-03-2003 02:45:19
HEF,
I don't know too much about this, but I looked in a catalog that sells short blocks.
According to it, the casting number for an "H" is #6695. For Super H is lists #362742.
The only things I see that start with 37##### are for a 404, a 504, a 766, and an 866, but none of the numbers match 372544.
Don't know if this helps any or not !
Maybe someone else will jump in here and help.
Gary
