Belt pully gear box for A
RobertN
10-02-2003 21:55:54
Just got a belt pully gear box. Thought I'd add one to my '41 "A".
I have not pulled the blank cover off the tractor yet. Will I find the drive gear/shaft for the pulley gear box behind the cover? Or, will I have to get an additional gear/output shaft?
The manual shows a gear meshing with the gear in the pulley gearbox.
gene b
10-03-2003 03:15:02
 Re: Belt pully gear box for A in reply to RobertN, 10-02-2003 21:55:54
Did you get the tube that slides back and forth to enguage the pto. It has a two prong end and the other end has a grouve for the lever that moves it back?
RobertN
10-03-2003 07:41:33
 Re: Re: Belt pully gear box for A in reply to gene b, 10-03-2003 03:15:02
I'm not sure... The tractor already has an operational PTO. This pulley gear box looks like they just undid the four bolts and popped it off the back of a tractor.
Merlin
10-03-2003 07:58:08
 Re: Re: Re: Belt pully gear box for A in reply to RobertN, 10-03-2003 07:41:33
Robert, I had a Super A with a PTO which had a straight shaft coming out. I took the domed cover off the top of that and just bolted the pulley gear box on. Didn't take but a few minutes and works great. Don't throw the domed cap away. I don't know what years were the same though.
