H farmall pistons
Mike Rooker
10-03-2003 17:40:12
I tore down a h farmall today that had a stuck valve the short block looks like new with hone marks still in the sleaves. But the pistons have a half rased dome Is this a super h piston or a aftermarket one all it says is front and thats it just was wondering if i got lucky on it or if it will mean nothing. Thanks Mike
randy hall
10-03-2003 20:37:20
 Re: H farmall pistons in reply to Mike Rooker, 10-03-2003 17:40:12
your pistons are stephead pistons. if they are ih pistons they would be listed as 5000' high altitude, they could be tractor supply or any aftermarket supplier.
JW
10-03-2003 18:41:39
Sounds like a M&W to me. Are you sure that LA is factory lp? I thought they didn't come factory till 52. Either way it looks like a nice tractor, wish it was closer
Mike Rooker
10-03-2003 19:51:42
 Re: Re: H farmall pistons in reply to JW, 10-03-2003 18:41:39
Yes it has the right casting as to the parts book Mine showes 48 and up but you maybe right also and was sent back to dealer and had the factory stuff put on? You cant be sure with 50 year plus stuff. Mike
