Bob M, I need your help
Tom W.
10-04-2003 12:58:58
2 years ago I wired my M per your 12 volt instructions and everything worked fine. Last week i started the tractor and the light stayed on. I looked at the belt and the fan was not turning. the bolt in the belt flange came out. Got that fixed and the light was still on. took the altinator off and to auto zone and had it tested. It is Ok. Printed your instruction off again and check all the wires, which were new. all ok. Took junper cables and ran a ground from the alt. to the Battery. still won't work. Nothing wlse has changed. motor still goes to full rpm, What am I missing?
Doug in OR
10-05-2003 10:56:09
 Re: Bob M, I need your help in reply to Tom W., 10-04-2003 12:58:58
Try running a wire directly from your battery to the number 1 terminal on the alternator - the same terminal as your light. If your alternator starts to work at this point, the problems is in the exciter wiring. I am assuming that you have the number 2 terminal wired directly to your BAT stud.
