Serial# on a H farmall?
Mike Rooker
10-04-2003 13:39:09
I have a few H farmall's two are 43's one has a x after the # what is the x for I have one of every year but this one i just got in has this x. does it mean anything.
earlschieb
10-04-2003 20:10:00
 Re: Serial# on a H farmall? in reply to Mike Rooker, 10-04-2003 13:39:09
And X1F is gasoline, and high speed gears. That is what mine has.
Paul in Mich
10-04-2003 14:17:03
Mike, Suffix "X" is Kerosene, "X 1" is Gasoline, No suffix is Distilate. Both Kerosene and Distilate tractors had the small gasolene tank to the right front of the main fuel tank. Many of these tanks were removed through the years as they were converted to Gasoline only. Thats why you may see a hood with an extra hole on the right side. During WWII, Kerosene and distilate fuel was cheaper and more readily available than was gasoline which was expensive as well as in short supply.
CNKS
10-04-2003 19:47:49
 Re: Re: Serial# on a H farmall? in reply to Paul in Mich, 10-04-2003 14:17:03
I believe the only fuel suffix that is reasonably consistent is X1 for gasoline. Guy Fay's data book lists X3 as kerosene and X17 as distillate. My 41 H is either kerosene or distillate, and has no suffix. I probably can check the part number on the head to find out what it is.
