Alternater and wiring Harness on Super M
Jack in Fla
10-04-2003 13:41:21
Want to put an alternater on my super M, can I buy a wiring harnes to replace the original? That would eleminate the voltage regulater.
Jack in Fla
Doug in OR
10-04-2003 16:15:31
 Re: Alternater and wiring Harness on Super M in reply to Jack in Fla, 10-04-2003 13:41:21
You only need two wires to that alternator. One would go to your voltmeter or ammeter, the other to your ignition switch, through a lamp or diode. In any event, both wires would be going to your switchbox. Just get a piece of 3/8 inch plastic wire loom and put the two wires in it. You can also bring a third wire out and exit the loom for your ignition wire. It looks very professional when you are finished.
Jack in Fla
10-04-2003 17:07:53
 Re: Re: Alternater and wiring Harness on Super M in reply to Doug in OR, 10-04-2003 16:15:31
Thanks for the reply Doug, don't know why I did not think of that.
Jack
