Leaking Bolts on Pan of Farmall B
Roger
10-04-2003 18:22:38
I just finished restoring a Farmall B and for some reason I am getting oil leaking out of several of the pan bolts. It only leaks when I run the engine, which I suppose is just from the oil being slung around in the block. I know some of the taped holes for the pan bolts may go through, but I haven't had them leak on other tractors. I used a silicone sealant on the pan gasket so there are no leaks through the gasket. I am thinking of pulling out the bolts that leak and coat them with non hardening Permatex. Have others had this problem? Roger
Van
10-05-2003 05:11:46
 Re: Leaking Bolts on Pan of Farmall B in reply to Roger, 10-04-2003 18:22:38
Rodger,
Silicone is for models breasts, it just makes them look better in thier opinions(some of them leak too). Use the permatex avialtion sealer on assembly for a leak free job, also check that the pan bolts are not distorted from over torquing of bolts in the past.
Van
Jonathan Mirgon
10-05-2003 01:30:40
I have an (a) and am having the same problem, I knew that the pan bolts were not blind so I coated all the pan bolts with silicone, And they are right through the silicone away it doesent work mine still leak, I am too still looking for a solution.
Phlogiston
10-04-2003 20:46:01
Also, while you have the pan off, make sure the bolt holes in the pan are nice and flat. They get bent out of shape from over-tightening.
Phlogistion
David A
10-04-2003 19:25:45
You're on to the problem - the tapped through bolts. I tried some Orange colored Permatex, mostly because it is similar to the paint color. It worked for awhile, but is now leaking, so skip that product.
Dave_Id
10-04-2003 19:16:27
Throw the silicone away, and buy a can of Aviation Permatex at your Napa store and coat those bolt on assembly... This stuff is the cats meow.
Bud
10-05-2003 09:15:12
 Re: Re: Leaking Bolts on Pan of Farmall B in reply to Dave_Id, 10-04-2003 19:16:27
I'm having the same problem with my Super C. Have you actually been successful in sealing leaks through the bolts by applying Aviation Permatex?
How much did you put on the bolts?
Thanks
Dave_Id
10-05-2003 12:26:28
 Re: Re: Re: Leaking Bolts on Pan of Farmall B in reply to Bud, 10-05-2003 09:15:12
Yes, I just smeared it on like you would a pipe fitting.. Works real well
WME
10-06-2003 13:49:45
 Re: Re: Re: Re: Leaking Bolts on Pan of Farmall B in reply to Dave_Id, 10-05-2003 12:26:28
The local Case/IH dealer advised that I put no sealant whatsoever on my Super C cork gasket that I purchase through him. If you do, he said, it will leak.
