656D Specs.
Tim Severson
10-05-2003 20:12:23
I'm looking at a 656D Farmall with the T.A. Can anybody help me find the M.P.H. for the 10 forward speeds? Thanks for all your help. TIM
TL
10-06-2003 03:58:19
 Re: 656D Specs. in reply to Tim Severson, 10-05-2003 20:12:23
According to the manual it shows no difference between gas or diesel.Based on 15.5-38 r-1 tire.1st normal 2-1/2,ta 1-3/4.2nd normal 4,ta 2-3/4.3rd normal 5,ta 3-1/2.4th normal 7,ta 4-3/4.5th normal 16,ta 10-3/4.rev normal 2-3/4,ta 2 .This is at 1800 rpm.There is a difference on hydro.1st F 2-1/2,R 3.2nd F 4,R 5.3rd F 5,R 6.4th F 7,R 8-1/2.5th F 16,R 19-1/2.With 16.9-34 r-1 tires 1-1/2 percent less,With 14.9-38 r-1 and 18.4-34 r 1 tires 3 percent greater.
Hugh MacKay
10-06-2003 02:31:39
Tim: I don't have but am sure it will come. If not I have the figures for the Farmall 544, they will not be exact but having owned a 656 in past, I can say they are close. The ratio between gears will be exact. If you don't get a responce in 24 hours I will post these. This is IH sales literature and 544 on 13.6x38 tires I imagion 656 would have been done on 15.5x 38 tires. I don't remember for sure. For the time involved I will do it now. 1st- 2-1/2 and 1-3/4, 2nd- 4 and 2-3/4, 3rd- 5 and 3-1/4, 4th- 7 and 4-3/4, 5th- 18 and 12-1/4 and reverse- 2-3/4 and 2. In each case first figure is direct and second is TA
