Super A Hydraulic specs.
C. Jackson
10-06-2003 14:05:12
I need to know the gallon per minute and PSI
generated by the hydrualic on a Super A. I am
going to add power steering and will have to
have this information. Thanks
gene b
10-06-2003 19:16:52
 Re: Super A Hydraulic specs. in reply to C. Jackson, 10-06-2003 14:05:12
The pump will run your power steering well but your rockshafts will work slower and weaker while you are turning at the same time. Mite want to add a seperate pump for the power steering.
uglyoldfatman
10-06-2003 17:38:50
Brian;
I just got a '49 SA, and am trying to find time too work on it.
The question I have is, why do you want power steering ? Are you going to add something to the front to make it harder to steer ?
Thanks.
UG!
C. Jackson
10-06-2003 19:45:20
 Re: Re: Super A Hydraulic specs. in reply to uglyoldfatman, 10-06-2003 17:38:50
I am putting power steering on it for a woman
to use to mow the lawn. Also as a novelty as
I have never seen a Super A with ps. It has
the Woods L59 belly mount mower. Thanks for all
of your help.
Brian
10-06-2003 17:02:12
I believe the pump is 4.5 gallons and the max. pressure is 1500 psi.
Brian.
