MD vsM
Lary
10-06-2003 17:50:01
Is a Farmall MD longer than a Farmall M , the sheet metal looks dif.thanks Lary
Geoff
10-07-2003 15:12:28
 Re: MD vsM in reply to Lary, 10-06-2003 17:50:01
The other thing that is different is the front section of the steering column, as I found out trying to find a replacement.
brianh
10-07-2003 06:17:46
The book spec shows the MD as 1 1/2" longer than the M. The difference is in the length of the engine, and the frame rails are different to make the implement mounting holes on the side line up the same as an M.
Roger
10-06-2003 19:48:31
I thought the M and MD were the same length. They allow mounting the same implements that mount front to back axle. From my MD it looks like it has the same side rails, but the front engine mount is on the top of the rail instead of by the two bolts through the side of the rail as is with the straight M. You can also mount the same implements on an H. Roger
Haas
10-07-2003 06:20:35
 Re: Re: MD vsM in reply to Roger, 10-06-2003 19:48:31
If you measure your MD side rails and the side rails on an M you will find yours to be longer. Yes, same implements mount on the M and the MD. Apparently IH allowed for this in the implement designs, or the difference is not enough to matter.
MD side rail part numbers
Left Hand 360519 R91
Right Hand 360520 R91
M Side rail part numbers
LH 61329 DD
RH 61330 DD
Parts catalog does not give length. Other differences besides length. The reason for the difference is that the diesel engine is longer than the gas.
Haas
10-06-2003 18:35:40
The MD is a little longer than the M. The side rails are longer as is the hood. I suppose the steering shaft, and other parts are different as well.
Lary
10-06-2003 20:20:42
 Re: Re: MD vsM in reply to Haas, 10-06-2003 18:35:40
Hass; Thanks for clearing it up for me,I saw them side by side and thought I was seeing things. Lary
