3 PIONT WIDE FRONT
FARMIN RED
10-07-2003 07:49:45
Does anyone know is there plans out there some place to build you own 3 point.(for an H) If so where can I find them? I also am thinking of a wide front for the H. I first need to locate one but what are the steps to the swap.
Farmer Bob
10-07-2003 10:47:00
 Re: 3 PIONT WIDE FRONT in reply to FARMIN RED, 10-07-2003 07:49:45
There may already be holes in the bottom of the upper bolster housing to mount the WFE. You will have to clean those holes out and chase the threads cause more than likely they are full of mud, manure and other madness. There may or may not be holes in the bottom of the frame rails to bolt the WFE stabilizer arms to so you may have to drill for them. I'm sure there are plans out there for building your own three point but can't help you out on that.
