Warm starting
Ed
10-07-2003 09:57:00
My '53' Super A fires right up after only two or 3 revolutions when cold, but starts hard when it's warmed up. Would that be a fuel or electrical problem? Any suggestions would be appreciated.
Ben in KY
10-07-2003 20:11:12
 Re: Warm starting in reply to Ed, 10-07-2003 09:57:00
When it does start back up warm, does it puff out black smoke ? Or any other symptoms youcan think of ?
David Bacon
10-07-2003 19:41:04
Very big odds on a defective coil. Dave NE Iowa
brianh
10-07-2003 11:28:14
It's easy enough to tell. When it's warm, pull a plug wire and connect it to a spare spark plug and lay it on the block. Crank and check for spark and then you will know.
Farmer Bob
10-07-2003 10:39:55
Could be the coil is starting to break down.
williamf
10-07-2003 12:57:35
 Re: Re: Warm starting in reply to Farmer Bob, 10-07-2003 10:39:55
On my H it was either the coil or the condenser - I replaced them both at the same time so I would never be sure. If I had known what a pain the coil would be I would have tried the condenser before I ordered a coil.
Wm
