Re-powering an M
Mguy
10-07-2003 19:56:44
I've got an M -no sheet metal, no engine, drive train good. I was wondering ,What's the slickest diesel re-power you've seen in an M or SM?
mark
10-12-2003 19:06:23
 Re: Re-powering an M in reply to Mguy, 10-07-2003 19:56:44
two stroke diesel-detroit only way to go
cheap, simple, easy to rebuild, powerful, and best of all LOUD
Andy
01-11-2004 18:53:40
 Re: Re: Re-powering an M in reply to mark, 10-12-2003 19:06:23
I was wondering if anyone has a kit to put a 3-71 into a Farmall M or what they consist of. I have a 3-71 Detroit and a M with a bad motor and thought this would be a good project.
Thanks,
Aces
10-09-2003 05:10:22
I know of a SM with the 436 from a 1466 the big thing was the back plate on the back of the block and use the side rails from the 1466.
Simp
10-08-2003 19:44:16
I have never seen it, but I would like to see someone put a 5.9 liter Cummins in an M or SM. Always thought I would like to try it, but that would probably take a lot of time I don't have.
Richard C
10-08-2003 08:14:18
At a show once I saw one with a GM Diesel. Probly a 6.2 Looked real good though
Richard
Red Dave
10-08-2003 05:06:08
I've seen M's with 2 cylinder Detroit and Shepard diesels. I was told they were offered as conversion kits back in the '50's.
SAm in NS
10-08-2003 15:42:42
 Re: Re: Re-powering an M in reply to Red Dave, 10-08-2003 05:06:08
From what's been said on this board earlier the Shepard Diesel conversion sounds like the fastest way to turn an M into an H. SAm in NS
Mguy
10-09-2003 02:45:34
 Re: Re: Re: Re-powering an M in reply to SAm in NS, 10-08-2003 15:42:42
Sam, I've heard the same thing about that Sheppard conversion kit. No, this would be a user tractor so fuel use is a factor as well as reliability; that's why diesel. I'm getting a lot of good info from you guys, that's why I asked here, thanks. Mguy.
Larry
10-07-2003 20:24:11
I saw a six cylinder M once. Someone took a 856 gas motor and put it in an M. They lengthened the frame and hood and it looked original. I would imagine an 856 diesel, 560/706, 766 and on and on... would work. Go for a 466 motor.
Mguy
10-07-2003 21:40:41
 Re: Re: Re-powering an M in reply to Larry, 10-07-2003 20:24:11
Larry, that 466, is it what a whole lot of IH trucks and 1066's use? Mguy.
Larry
10-08-2003 05:07:36
 Re: Re: Re: Re-powering an M in reply to Mguy, 10-07-2003 21:40:41
I believ the 466 was used in trucks and the 1586. The 1066 had a 413 in it. Don't get to big or you'll rip up your transmission or simply flip the tractor over.
