Farmall M part # for PTO Bearing Housing Help
David
10-08-2003 08:52:06
My home made 3 point hitch and over running coupler pushed the PTO shaft in. It broke the bearing and the housing. The seal was also destroyed. I am looking for a new one and it would help if I had the part number. I will lengthen the lift arms to 36" on the 3 point hitch to prevent this from happening again.
rastas
10-08-2003 11:54:30
 Re: Farmall M part # for PTO Bearing Housing Help in reply to David, 10-08-2003 08:52:06
Early model M.....8955 DX ( ORDER 60826 D)
LATER models..... 8955 DAX
LAST MODELS ..... 9576 DX
David not sure of change over dates but I am fairly sure that the last type started with serial no FBK 59957.
Good luck hope you soon get it sorted, Rastas.
