Super A center steering arm removal??
Skeeter
10-08-2003 18:05:35
Hello,
I'm in the process of fixing up a Super A (s/n311906). The center steering arm is badly worn and I need to replace it. As I don't have a service manual yet, I was hoping someone here could tell me the easist way to get make the swap. Mine has the tapered shaft design. Looks as though the axle has to come off, is this correct? Will the it just slide out of the pivots or what? Is there a better way? Thanks, Skeeter
Hugh MacKay
10-08-2003 19:25:55
 Re: Super A center steering arm removal?? in reply to Skeeter, 10-08-2003 18:05:35
Skeeter: The pin on the pivot has to come out. The hardest job here is getting that U bolt that goes around axle just at left of pivot. I have always found it easier to unbolt the wheel tread adjustment on the left side and slide that right out. Besides once that front axle is in two pieces it is a lot easier to handle.
You may find the key way for the woodruff key on the tapered shaft is out of shape. I had to grind a larger key to fit as key way was V shaped. On one tractor we actually welded the key in shaft and ground it so steering control arm had to be pressed on. That one was also the most sucessful. It has been 10 years and the tractor steering is as tight as the day it was new. Everyone told me I would ruin shaft. I advised it was already ruined. Those shafts and cogs are quite expensive even at scrap yards.
