front pump drive adaptor
Mac
10-09-2003 11:36:25
I hear there is a front pump option for IH. Does that include C/IH 485-380B industrial. I need an adaptor for pump drive shaft. Also is tran housing enough oil volume for 20gpm or do I need seperate reservoir. I'm installing an industrial loader (Ford 712) with 3" cyls and 3pt hoe.
Thanks for any info,
Mac
Ben in KY
10-09-2003 13:55:34
 Re: front pump drive adaptor in reply to Mac, 10-09-2003 11:36:25
I have a 2444 with front pump and 2050 loader. On mine I have to run 17 gal of HYTRAN in the tranny. If no fromt pump it would only be 5 gal in the tranny. There is also 3 gal in the lift box for both configurations. So without any front pump the 2444 uses 8 gal total of HYTRAN. With the front pump it uses 20 gal !
This is all from the origional operators manual.
Mac
10-10-2003 05:07:39
 Re: Re: front pump drive adaptor in reply to Ben in KY, 10-09-2003 13:55:34
How does your pump attach and what drives it? This pump ran off crank damper/pulley previously. My book doesn't mention a pump. I can make it work with a 10 spline coupler welded to a plate that bolts on damper, but would rather set up with an original IH pump drive.
