Farmall M / 400
Richard Fazio
10-09-2003 15:26:57
I figured I'd check with the farmall guys. Can anyone tell me if a 400 is about the same size as an M, and the 300 is about the same size as an H? How about HP for each? I tried finding info on these tractors and the specs are hard to find. This site lists some of the farmalls under serial numbers but not all. Where is a good Farmall site for specifications. Thanks
Richard Fazio
10-11-2003 10:16:46
 Re: Farmall M / 400 in reply to Richard Fazio, 10-09-2003 15:26:57
Thanks for all the info guys. I'm going to be getting myself a Farmall very soon. I'll let you know what I got.
TimV
10-10-2003 05:54:07
Richard: While I won't attempt to add any of my (limited) knowledge on this particular subject, the link below does have some good Farmall info.
Farmall450man
10-10-2003 05:30:57
Richard, the others have answered about the HP. The 400/450 & 300/350 were a few inches longer than the the M & H due to the addition of the TA. The housing ahead of the transmission is a little longer. The weight also increased due to the extra iron in the housing, larger fluid capacities, and the live PTO. So you're looking at a few inches and around a 200 or more pounds. The extra weight isn't significant when compared to the possibility of fluids in the tires, as this would potentially be a big difference from a tractor with fluid in the tires versus one that doesn't have fluid in the tires.
CNKS
10-09-2003 18:25:16
Anything you need to know will be found in the answers on this board -- for specs check www.weberstractorworks.com. The answer to your 1st question is yes. Sequence was H/Super H/300/350/460, and M/Super M/Super MTA/400/450/560. The 460 and 560 were 6 cylinder tractors, vs 4 for the others, and had several improvements, but were based on the H and M series.
bbauman
10-09-2003 16:55:35
Info from>Link
Drawbar>Link HP
H 20
SH 26
300 27
M 25
SM 33
400 36
Farmall Boy
10-09-2003 16:13:15
M=248 cubes (but chances are its been rebuilt to 264)
Super M=264 cubes
400=264 cubes
