Super M - hydraulic lever position?
bbauman
10-09-2003 17:12:38
On a Super M with live hydraulics, what position should the lever be in?
Not sure if it matters but my plumbing goes from pump to a 2 spool valve. From valve to resevoir.
Also, the spool for the loader is a 4 way (2 way hydraulics), loader cylinders are one way hyd. So one of the hoses on that spool goes to one of the connections by your left foot. Is that alright?
thanks.
Dan
10-09-2003 20:57:29
 Re: Super M - hydraulic lever position? in reply to bbauman, 10-09-2003 17:12:38
Does this tractor have the reservoir under the rear of the gas tank with lift all lever on the right side? If so to operate 2 way valve the lefer should be in the locked foreward position. The 2 fittings on the left side are pressure ports when using the lift all.
bbauman
10-09-2003 22:29:03
 Re: Re: Super M - hydraulic lever position? in reply to Dan, 10-09-2003 20:57:29
Yes, the reservoir is under the gas tank. There is a lever on right side of the resevoir. It has a lock to lock it back, but not forward. 3 ports are by the left foot of the driver.
Bob M
10-10-2003 04:19:07
 Re: Re: Re: Super M - hydraulic lever position? in reply to bbauman, 10-09-2003 22:29:03
You got it! That lever on the reservoir (the "Lift All" lever) must be latched to the BACK for the remote 4 way valve to work.
Dan
10-10-2003 06:25:26
 Re: Re: Re: Re: Super M - hydraulic lever position in reply to Bob M, 10-10-2003 04:19:07
That 's what I get for not going and looking at mine. Guess it's cause I never move it.
Bob M
10-10-2003 08:27:49
 Re: Re: Re: Re: Re: Super M - hydraulic lever posi in reply to Dan, 10-10-2003 06:25:26
Hey Dan - you're in good company on that one! I only remember the lever must be latched back when the remote cylinder I mine would not work as I was hooking a plow a couple weeks ago. After a couple frantic moments I figured out the Liftall lever (which has no pull rod attached) had gotten kicked into it's center position by someone's big foot. Latching it back got the remote working again.
