434 (424) Special Auxillary Unit, Need Name
BlueLite
10-10-2003 08:59:31
My 434 has the standard double spool auxillary unit, so to use it I have to turn off the shutoff valve to the 3PH. I heard they sell a special replacement unit that allows for both 3PH and aux to be used at once. The name is something like "Power ----" and I forget the second part. They say they're not cheap either as it has a special bypass chamber built in or something like that.
Any help will be appreciated.
Thanks.
parts man
10-10-2003 16:23:03
 Re: 434 (424) Special Auxillary Unit, Need Name in reply to BlueLite, 10-10-2003 08:59:31
They're called "power beyond" because the hyd fluid goes through the valve body first, then to your 3 pt hitch. You need to replumb the pressure line from the pump to go into the aux valve, and from the valve into the 3pt unit.
