504 steering
jb
10-10-2003 21:05:59
steering is decent but not good, if your stopped it's like iot doesnt work until you can get moving, if your moving it's fine with little "hard" spots as you turn the wheen. Is it the assist unit up by the steering wheel or the hyd pump? What else could it be?
TomH
10-11-2003 15:43:46
 Re: 504 steering in reply to jb, 10-10-2003 21:05:59
Could be the hydraulic fluid is low. Mine doesn't work all that well at low RPM, and even with the engine at speed the steering is hard when you're standing still.
Joe
10-11-2003 16:20:56
 Re: Re: 504 steering in reply to TomH, 10-11-2003 15:43:46
Is your pump whining any? Are you hydro filters clean? I know mine was hard steering when I first got it. I pulled the filters, changed oil and now it works alot better. Still alittle hard steering when on a uphill slope at times.
