Liquid block sealer being used in thermosiphon sys
Jonathan Mirgon
10-11-2003 08:49:46
I have an (a) that is getting a very small amount of coolant in the oil.(almost undetecable) Im wondering if anyone has used the liquid block sealer in a thermosiphon system.being as there is no waterpump i am not sure if this soulution will circulate through the system enough to do its job.Or if it would cause a problem if used in this type of system.
Nebraska Cowman
10-11-2003 18:10:22
 Re: Liquid block sealer being used in thermosiphon in reply to Jonathan Mirgon, 10-11-2003 08:49:46
I have had good luck with radiator leaks using the aluminum powder sealant. I just dump it in and let the motor warm up good. Don't know how it would be on the block.
James Williams
10-11-2003 17:41:46
Jonathan,I used a block sealer on my F12,I think it was k&d or something like that,It was the metalic type sealer,and it worked perfect.The way I under stand you must follow directions.Flush all antifreeze out of motor,mix sealer with hot spigot water, run for at least one hour at a steady speed,do not rev up,several hours would be better,turn motor off,let cool,drain water out of motor,let sit empty for atleast 24 hours or longer,than refill with coolant.
F-Dean
10-11-2003 12:57:42
Jonathan, I did something similar when I was repairing a F-20. I blocked the lower block outlet to the radiator and filled the block with concentrated sealer for a few weeks while I worked on other parts. Dean
