Magneto Timing.......Is there such a thing ?
Scotty
10-11-2003 18:42:30
I have a Farmall C ,.... it has a magneto distributor,..... the shaft that the rotor button sit's on has been taken out , this shaft that the rotor sit's on has a gear on it that is driven by, another gear , when I put the shaft back in the dist. I think I may have moved the gears, if I did do I have to time the two gears? Thanks for any help..... ..... Scotty
MD Wa.
10-11-2003 19:43:12
 Re: Magneto Timing.......Is there such a thing ? in reply to Scotty, 10-11-2003 18:42:30
Scotty. If you clean the gears good you should see on one gear two teeth that have been ground down just a little. On the other there will be one tooth that has been ground, that tooth goes between the two on the 1st gear. LOL Morgan
Scotty
10-12-2003 02:53:02
 Re: Re: Magneto Timing.......Is there such a thing in reply to MD Wa., 10-11-2003 19:43:12
Thanks, I knew if it was anyway to get it out of time I would be the man for the job,Thanks for the info I will be checking that first thing this morning..... Thanks Scotty
Scotty
10-12-2003 11:18:51
 Re: Re: Re: Magneto Timing.......Is there such a t in reply to Scotty, 10-12-2003 02:53:02
HI, FOUND THE SMALL GEAR TO HAVE ONE TOOTH MACHINED DOWN BUT THE BIGGER GEAR THAT THE ROTOR SETS ON DOESN'T HAVE ANY THING ON IT THAT I COULD FIND SO I USED THE NOTCH THAT THE ROTOR LOCKS INTO AND LINED UP THE MACHINED TOOTH.IT LOOKS RIGHT, WHEN THESE MARKS ARE LINED UP THE ROTOR POINTS AT # 1 AT THE DIST. CAP ,ALSO WHEN I LINE THSE MARKS UP AND WIND THE MAG. UP THE ROTOR POINTS AT # 1 AT THE CAP . I'LL GIVE THAT A TRY THANKS FOR YOUR TIME AND HELP..... ..... SCOTTY
KBBob
10-12-2003 15:35:38
 Re: Re: Re: Re: Magneto Timing.......Is there such in reply to Scotty, 10-12-2003 11:18:51
Scotty
On the end of the rotor shaft are the letters R and L. These letters are hid with the rotor installed. Since you have a right hand magneto, use the letter R and and draw a straight line down to the gear teeth. Using the 2 teeth that lines up put them in mesh with the small gear with the bevel. Good luck.
Scotty
10-12-2003 18:05:12
 Re: Re: Re: Re: Re: Magneto Timing.......Is there in reply to KBBob, 10-12-2003 15:35:38
THANKS FOR THE INFO . I'M GOING TO TAKE THE DIST. BACK APART TO FIND THE R AND L ON THE ROTOR SHAFT CAUSED I USED THE ROTOR BUTTON NOTCH FOR THE MARK ON THE BIG GEAR.THANKS ALOT FOR YOUR TIME AND HELP..... .... SCOTTY
