Farmall B, pto problems
maverick
10-13-2003 04:49:29
Have 1947 farmall B, rear pto quit today while pulling mower, belt pulley still running. Pto not turning with mower hooked up, mower turning freely. when I unhooked mower pto would turn but seem to wobble slightly. Did not hear any unusual noises. Any suggestions, I guess I need to pull the pto shaft and check it out.
Chris
10-15-2003 11:20:03
 Re: Farmall B, pto problems in reply to maverick, 10-13-2003 04:49:29
I have a complete PTO from a 46 BN that should work on your tractor. I could probably sell it to you for less than you can repair yours. Send me a message if interested.
Dave BN
10-13-2003 18:15:15
Un bolt the PTO and Belt pulley housing and pull it out rearward. You'll want to drain the transmission fluid using the drain plug on the right side of the transmission at the rear (below the belt pulley). Most likely a broken gear which will be obvious when apart. Dave.
Yes
10-13-2003 15:11:19
