serial # letter (super C)
tim shanahan
10-14-2003 05:46:22
i recently aquired a super c with a the letter J at the end of the serial #. I have a book but the letter J is not in it for options. (high altitude?:maybe)
jimc
10-15-2003 13:13:09
 Re: serial # letter (super C) in reply to tim shanahan, 10-14-2003 05:46:22
This is out of my "parts Manual for the Super C"
A Suffix Letter Code, as outlined below, is added to the Chassis Serial Number as a means of identifying tractors with special features, thus facilitating servicing. This code applies primarily to special features that replace standard ports or units used internally but may also be used to identify tractors equipped with one of two or more optional ports wherein identification of said optional parts is deemed necessary to proper servicing. Each suffix letter used is stamped in the blank space following the serial number on the Chassis Serial Number Plate.
Attachments that do not effect replacement of standard parts or units have not been coded.
(Example: 100001BEJ represents a tractor with a 8000-Ft. High-Altitude Kerosene Burning Engine and Roclcford Clutch./
SUFFIX LETTER SPECIAL FEATURES OR OPTIONAL PARTS
ON CHASSIS SERIAL NUMBER PLATE
A DISTILLATE-BURNING ATTACHMENT
B KEROSENE-BURNING ATTACHMENT
D 5000-FT. HIGH-ALTITUDE ATTACHMENT
E 8000-FT. HIGH-ALTITUDE ATTACHMENT
J ROCKFORD CLUTCH
Sid
10-15-2003 02:02:39
My Parts Book TC-44A, 10-10-51, lists the following suffix code;
X1J Gasoline - 7 m.p.h.High Speed Gears - 5000ft. Altitude
X 23 Auburn Clutch.
However, nowhere in the book are there Part Numbers for these special features. Sid.
Red Dave
10-14-2003 07:03:42
I don't have my book in front of me at the moment, but I think it identifies the style of clutch that was in it from the factory. Again not positive, but I think J was for a Rockford clutch.
I hope sombody will jump in and correct me if I am wrong.
