460 PTO repair
Vern V
10-14-2003 07:28:07
PTO lever will not stay in position when pulled back to engage.
How big a job to pull unit and is there an adjustment or broken pin to be found?
Vern V.
10-14-2003 21:00:23
 Re: 460 PTO repair in reply to Vern V, 10-14-2003 07:28:07
I have the later 460, (1961) with clutch type PTO, but understand there is a later version with an inspection opening where breather is.
I am looking at trying linkage adjustment. However see that it is frozen.
Thanks,
Aces
10-14-2003 10:38:54
If you have the late PTO it locks out of gear and is over center for in gear adjustment is on the linkage.
Ohio Bill
10-14-2003 09:26:42
There is a small lock lever at the base of the pto handle which locks the handle forward and backward. It could be just a matter of there not being sufficient tension on this lever to lock it in the groove, or it may need lubed.
