300 Utility hitch
Ben in MN
10-14-2003 08:22:20
I would like to have a 3pt or fast hitch on my 300U. There is no sign that one was ever on it. I have 3 Hydra touch valves and use none of them. Should I try to locate a fast hitch and then convert it, or is there an aftermarket hitch that any of you have added that works well?
dick
10-14-2003 09:11:56
 Re: 300 Utility hitch in reply to Ben in MN, 10-14-2003 08:22:20
The 300U came with either a fast hitch (which included an anchor point for the top link for a 3-point hitch) or the older-style drawbar - you've apparently got the latter. If you check around, you should be able to find a fast hitch off another 300U or 350U which will bolt right onto your tractor at one of the salvage outfits, or in the classifieds. Good luck.
tdk
10-14-2003 21:13:52
 Re: Re: 300 Utility hitch in reply to dick, 10-14-2003 09:11:56
Fast-hitch is an easy addition to your 300U. Try YT classifieds or eBay!
Ben in MN
10-15-2003 05:46:17
 Re: Re: Re: 300 Utility hitch in reply to tdk, 10-14-2003 21:13:52
Thanks for the pointers. I will keep my eyes peeled for a used unit.
