M/SM/SMTA Grill Holes
Bud
10-15-2003 08:46:50
Can anyone explain the purpose for the two holes in the front of the M grill? Also why does the SMTA have an additional set further out on the grill? Thanks
Dr.EVIL
10-15-2003 09:21:34
 Re: M/SM/SMTA Grill Holes in reply to Bud, 10-15-2003 08:46:50
Holes closest to the center of the tractor are for a bracket to bolt on to support the outside ends of front mounted cultivators. The outer holes on SM-TA's, SH's, SM's, & the 300/350 & 400/450's were for a bracket that bolted on behind the grill to support cultivators the same way.
Bud
10-15-2003 11:03:02
 Re: Re: M/SM/SMTA Grill Holes in reply to Dr.EVIL, 10-15-2003 09:21:34
Thanks--Hopefully someday I will run across one with the cultivator attached.
Michael Soldan
10-15-2003 15:53:09
 Re: Re: Re: M/SM/SMTA Grill Holes in reply to Bud, 10-15-2003 11:03:02
H's have those holes as well, cultivators and mounted corn pickers I believe..Mike in Exeter Ontario
Dr.EVIL
10-16-2003 05:54:28
 Re: Re: Re: Re: M/SM/SMTA Grill Holes in reply to Michael Soldan, 10-15-2003 15:53:09
Hi MIKE....Yes, H's & M's had the holes towards the center for the support rod bracket to bolt on but I don't remember anything from the picker mounting to them. Dad had an M&W Super Snoot He put on the M when the picker was mounted and I don't think it even had the holes on the front center, Just the 4 grill mounting holes, 2 on each side. Guess Who's job it was to mount the Super Snoot? ;-) Clymer's book, 150 Years of IHC showed front mounted middlebusters using them as well. You were kinda limited on what You could mount to them since I think they're only 3/8" bolts. There were two styles of brackets available, a welded-up bracket that bolted on with spacers outside the grill and another bracket that bolted on behind the grill of a SM, SM-TA, 400/450 with eyebolts threaded into it for the rods on the cultivator. Dad had the external bracket and used it even on the SM-TA & 450 which could have used the internal bracket.
