Farmall 140, or Freight Train?
Greyson O. Nole
10-15-2003 14:04:59
I have a problem.....
I have been working on one of my Farmall 140's today. When it runs, it smokes like a freight train, only the smoke is white. Im not exagerating when i say freight train, it engulfs the tractor and surrounding areas. It is so thick you cant see or breathe in the drivers seat. It smokes white at all engine speeds, the smoke gets thicker with an increase in RPM. It also blows an oily sludge from the manifold. it also gushes oil out of the dipstick like an Oil Refinery, seriously though, it will sputr about 6 inches out of the hole if you remove the stick.
What could be causing this, and is it easily fixed?
.....the EPA's going to love me.....
Greyson.
Greyson Noles
10-16-2003 17:01:54
 Re: Farmall 140, or Freight Train? in reply to Greyson O. Noles, 10-15-2003 14:04:59
Actually, as it turns out, it was a stupid error. I now know that when you put 2 1/2 gallons of lift fluid in the wrong hole (I/E engine oil filler)the smoke turns white. Simple fix, though, drain the oil/hydraulic fluid mix, add the new oil, and it doesnt smoke anyomre.
Darn.... now i cant brag about my AmTrac...tor
Randy in NE
10-16-2003 04:44:35
If you are getting water in the pan then it will have a distinctive milky/creamy color and be pretty thick.
steve
10-15-2003 18:35:37
that volumn of white smoke means broken or scored piston, or failed piston rings. you are sucking oil into the combusion chamber and forcing exhaust thru the crankcase and out the vents and dipstick on the down stroke.
K-Mo
10-15-2003 18:06:36
I had the same thing when someone put stove fuel in the tank instead of gas.
As far as water or antifreeze. In most cases I have seen, once the water burns out of the cylinder, the white smoke will stop. Take the radiator cap off. If there are a lot of bubbles and foam in the radiator, then you do have a problem.
Good Luck,
K-Mo
Phlogiston
10-15-2003 16:51:15
Start with the most likely cause. Bad head gasket. Pull the head and have a look. White smoke means that you are burning anti-freeze. The reason oil is coming from the fill pipe is that coolant is displacing the oil in the pan and pushing it out. By the way, you are not supposed to take the oil cap off when it is running. Put a new headgasket on, torque it properly and in the correct sequence and see what happens. You will also need to change your oil filter and oil as the stuff in there is now contaminated and no longer protecting your engine.
Phlogiston
Phlogiston
10-15-2003 16:50:18
Start with the most likely cause. Bad head gasket. Pull the head and have a look. White smoke means that you are burning anti-freeze. The reason oil is coming from the fill pipe is that coolant is displacing the oil in the pan and pushing it out. By the way, you are not supposed to take the oil cap off when it is running. Put a new headgasket on, torque it properly and in the correct sequnce and see what happens. You will also need to change your oil filter and oil as the stuff in there is now contaminated and no longer protecting your engine.
Phlogiston
Bus Driver
10-15-2003 16:25:33
Broken or stuck oil control ring could cause this. Hole or crack in piston. Is the crankcase oil level proper- not too full?
Michael Soldan
10-15-2003 15:49:14
A Jeep I was repairing did that once, the white smoke was steam and prestone ran out the tail pipe...head gasket and warped head...about $150 and a day's work and we had her purring..your problem sounds like..... ..... get it?...good luck from Mike in Exeter Ontario
rustyfarmall
10-15-2003 14:24:13
You didn't by any chance put diesel fuel into the tank instead of gasoline did you?
