806 injector pump ?
TL
10-15-2003 16:31:32
While discing the injector pump started to drip fuel where the control rod hooks to go through the pump.The higher the rpm the more it drips.Would this require a rebuild,or could an average mechanic like myself fix it,check that, maybe below average,Thanks for any advice
Chuck's Repair
10-15-2003 19:23:32
 Re: 806 injector pump ? in reply to TL, 10-15-2003 16:31:32
This is a simple fix.Shut off fuel supply,remove top cover,use a screwdriver or small vise grip pliers to remove the clip that holds the two halves of the throtle shaft together and remove them and replace the worn o rings.
