farmall (h) should I buy it ?
Jonathan Mirgon
10-15-2003 17:15:05
I found a 1942 (h) that is an older restoration and looks pretty good, It runs and drives good, but smokes pretty bad, I assume it needs rings or the valve guides are worn. It had rear steel wheels that have been nicely cut and replaced with rubber.( does this hurt the value ?) It looks like whoever reastored it did it the cheap way , the paint looks good but they have cut corners by using cheap aftermarket gauges etc. I can buy it for 1,100.00 . let me know what you guys think, it looks like a pretty good buy to me . But I need your input I dont want to make a mistake.
Thanks for your help
Jon Mirgon
rustyfarmall
10-15-2003 17:59:34
 Re: farmall (h) should I buy it ? in reply to Jonathan Mirgon, 10-15-2003 17:15:05
The wheels will not hurt a thing, it makes the tractor rather unique I think.
I would be a little concerned about the smoking engine however, it's nothing that can't be fixed, but a rebuild kit is somwhere around maybe $800? I think I would offer the man around the $750 mark, go up some if you need to.
Don LC
10-15-2003 20:38:29
 Re: Re: farmall (h) should I buy it ? in reply to rustyfarmall, 10-15-2003 17:59:34
I would look for an other H
